Application Detection Rules Settings
The settings depend on the rule Type that you select. Choose from the following types:
Host Name
Table 1. Host Name Settings
SettingDescription
TypeSelect the type of rule: Host Name, Server IP Address, or Port Number from the menu.
ProtocolSelect the protocol: HTTP or HTTPS from the menu.
Host Name(Required) Type the host name.
Server IP Address Settings
Table 2. Server IP Address
SettingDescription
TypeSelect the type of rule: Host Name, Server IP Address, or Port Number.
ProtocolSelect the protocol: TCP or UDP from the menu.
Server IP Address(Required) Type the IP address for the server.
Port NumberType the port number. Range: 1-65535
Port Number
Table 3. Port Number Settings
SettingDescription
Port(Required) Type the port number. Range: 1-65535
