You can create a switch template during the network policy creation process, or at the device level after you have a network policy in place. Device-level changes to a switch template override settings in the network policy. For more detailed information about switch use in ExtremeCloud IQ, see the ExtremeCloud IQ Universal Switch Deployment Guide.
A switch template is a visual depiction of the physical ports on a switch. Configure how ports function by assigning port types and port usage settings to the template, and then applying the template to managed switches. The following steps describe how to create a switch template inside the network policy creation workflow.
Under Device Configuration, you can choose to override settings made under Common Settings in a network policy. The Switch Template Override feature allows you to create and manage switch templates based on common settings for the SwitchEngine, ExtremeXOS, Fabric Engine, and VOSS platforms. These common settings include STP, MAC Locking, IGMP, Extreme Loop Recovery Protocol Settings (ELRP), MTU, PSE, and Management Interfaces (Switch Engine only). The default values for these settings are defined within the common switch settings for each platform type. When you create a new switch template and enable the override option, you can customize device configuration settings that will override the network policy switch common settings. If the override option is disabled, the network policy common settings inherit the device configuration.
To make changes to a switch template at the device level, go to Manage > Devices and select a device name.
Use this task to configure a switch template.
MAC Locking must also be enabled on a per-port basis.Note
ELRP must also be enabled within the switch template.Ports configured as trusted do not apply the drop action. By default, port types configured as Trunk Port are trusted.
Continue configuring the network policy. To create a switch stack template, see Manually Create a Switch Stack.
Section contents:
