Customize Other Options
Complete the Add a Network Policy task.
This task is part of a series for configuring the Optional Settings for a standard wireless network. Use this task to customize the Other Options.
  1. Go to Configure > Network Policies.
  2. Select an existing policy, and then select Edit.
  3. Select Next to open the Wireless Network page.
  4. Go to Additional Settings > Optional Settings, and then select CUSTOMIZE.
  5. Select Ignore broadcast probe request to enable Extreme Networks devices hosting this SSID to ignore probe requests from wireless clients.
  6. Select Hide SSID (Stealth mode) to enable a simple but ineffective method to secure a wireless network; it hides the SSID (Service Set Identifier).
    This method provides very little protection against anything but the most casual intrusion efforts.
  7. Select FTM(11mc) Responder Support to enable client devices to determine their distance from the AP.
    If the civic address, latitude, longitude, or altitude of the AP is configured, the AP advertises this information in the beacon.
    Enabling FTM (Fine Timing Measurement) 11mc causes a radio reset.
  8. Select Enable enhanced RNR to enhance roaming for 6 GHz clients, or clear the check box to turn off this feature.
    If you select Broadcast SSID Using > 6 GHz radio, ExtremeCloud‌ IQ enables this feature by default. If you turn off 6 GHz radio, ExtremeCloud‌ IQ disables this feature.
  9. Select SAVE OPTIONAL SETTINGS to save your changes.
Finish configuring the network policy.
