Changing Operating System Persona for Onboarded APs
If the AP model supports multiple operating systems (ExtremeCloud IQ, ExtremeCloud IQ
Controller, or WiNG), you must select either Cloud Onboarding (ExtremeCloud IQ) or Local
Onboarding (WiNG) when onboarding the device.
If locally onboarded, ExtremeCloud IQ issues a command to the AP switch to WiNGOS and then issues a delayed reboot command:
For most Universal APs:
The AP boots into WiNG in discovery mode.
The AP searches for the controller's DHCP or DNS address, or performs local discovery
within the subnet.
Depending on the controller instance's configuration, the device reboots
into either CCC mode or WiNG Distributed mode and then connects to the
controller instance.
WiNG Distributed mode is not supported on AP4000 devices. These devices boot directly into WiNG CCC mode for use with ExtremeCloud IQ
Controller.
For AP3000/AP4020/AP5020 devices, administrators can set up to two controller URLs in
ExtremeCloud IQ during onboarding. Once the device switches to WiNG, the
device contacts ExtremeCloud IQ to retrieve the controller address
assignments.
Tip
Troubleshooting connectivity to ExtremeCloud IQ Controller after switching OS:
The AP must complete a region and country check before OS conversion. If the AP reports
Region as World with Country as 998, offboard the AP and re-onboard it to retrigger the region
check.
If the AP region and country does not match your Site region and country defined in ExtremeCloud IQ
Controller,
the AP may not be able to onboard. Place the AP in the site with the correct region and country
defined on the AP.
