The following options appear at the top of the Plan Devices tab
when you are adding a floor:
Choose Devices: Displays the number of devices available to
deploy. Use this option to assign real, simulated, and planned devices to the floor
plan.
You must first Onboard the devices before you can assign them to a
floor.
Auto Plan For: After you select the location wireless
coverage type (basic, high-speed, voice, or location tracking), select
Auto Place to automatically place the devices in the optimal locations for the
selected wireless coverage type.
Add Devices: Manually
place devices based on radio band (5 GHz or 2.4 GHz), device model, signal strength,
channel, and power. Select More to see additional settings
for this function.
After you have placed simulated or planned devices on a map, or after you have onboarded
real or simulated devices, you can view the Heat Map for
all devices.
