CAPWAP Connection
  1. The AP discovers ExtremeCloud IQ through one of four mechanisms, executed in the following sequence:
    • DHCP option 43
    • DNS
    • Local subnet discovery
    • Redirector
      The Redirector is the primary mechanism for ExtremeCloud IQ. The AP will use DNS to find the Redirector IP address.
  2. The AP automatically discovers and CAPWAP connects to the redirector.
    Outbound UDP 12222 or TCP 80 is required.
    • By default, all CAPWAP connections first attempt to connect using UDP 12222. If unable to connect, the AP attempts to connect using TCP 80 instead.
    • Refer to the firewall guide to identify the IP address ports needed to permit traffic to the Redirector.
  3. If the AP serial number is onboarded to ExtremeCloud IQ:
    • The Redirector directs the AP to connect to the RDC master CAPWAP server by setting the command capwap client server name <CAPWAPMASTERHOSTNAME>.
    • The AP disconnects from the Redirector and CAPWAP to connect to the RDC master CAPWAP server.
    • The RDC master CAPWAP server directs the AP to connect to the CAPWAP server designated as the primary management instance for the device by setting the command capwap client server name <CAPWAPSERVERHOSTNAME>.
  4. If the AP is not onboarded to customer account, it continues to cycle through the AP discovery methods defined above.
Tip
Tip
CAPWAP Connection troubleshooting:
