A radio profile contains settings for the radios in APs. The radios generally operate in two frequency bands: radio 1 (WiFi0) operates at 2.4 GHz, and radio 2 (WiFi1) operates at 5 GHz. WiFi2 supports only the 6 GHz band for client access. The number of radios and frequency bands supported vary by AP model.
In the Radio Profiles window, you can view, add, modify, and delete radio profile settings. You can also modify radio profile settings when you configure a device template. See Configure Device Templates.
The Radio Profiles table displays the following information:
Section contents:
