AFC Wireless View
The AFC Wireless view shows all access points (APs )that support 6E Standard Power under Automatic Frequency Coordination (AFC) server control. A dashboard summary displays AFC Status, Geo Location, and AFC Mismatch information for the APs.
AFC is supported on AP5050 (outdoor) devices.
Important
Important
For AFC support, APs must be deployed to a site with Outdoor Mode enabled.
AFC Status and Geo Location are not related to the AP's current connection status. They indicate that the AP can function within the region it is connected to. If an AP is no longer connected, the AFC Status and Geo Location are not erased. Both the AFC Status and Geo Location remain unchanged until the expiration time is reached. When the expiration time is reached, the AFC Status changes to "Grace Period" and the Geo Location changes to "Not Available".
Go to Manage > Devices, then from the View drop-down list, select AFC Wireless.
AFC Service Connection Status
Select AFC Service to view the AFC service connection status. AFC service status indicates whether the device is successfully connected to the AFC server. The graph shows the AFC service availability for the last 24 hours
Table 1. AFC Service Details
FieldDescription
ModeIndicates if the AFC service is Connected or Not Connected to the AFC server.
AddressDisplays the URL or IP address of the connected AFC server.
CountryDisplays the country in which the AFC service is operating.
Time RangeThe displayed connectivity time range. To change the displayed time range, select 1 Hour, 2 Hours, 4 Hours, 8 Hours, or 24 Hours. 24 Hours is selected by default.
GraphDisplays the connectivity status for the selected Time Range. To see the connection details for a specific moment, hover over the graph timeline. A popup window appears, showing the date, time, and connection status for that particular point.
Select Clear Selection to reset back to the default time range.
To save the graph details for future reference, select the Chart Context Menu (chart context menu) icon, and then select one of the following options:
  • Print chart
  • Download PNG image
  • Download SVG vector image
  • Download JPEG image
  • Download PDF document
Graph Details
The AFC Status graph displays the status of each AP:
  • Available: AFC spectrum is available until 24 hours after the AFC server assigned the spectrum.
  • Pending: The initial state after the AP powers up. The AP waits for “Geo Location Available” and AFC spectrum response from the AFC server.
  • Grace Period: The AFC spectrum must be renewed every 24 hours. If the AFC server is not reachable, or not responding at the selected time, the status changes to Grace Period. The status remains in Grace Period until the next midnight UTC. If the AFC server stays down, the status changes to Pending and the radios are shut down. After the AFC server recovers, the status changes to Pending.
The Geo Location graph displays the geo location status of each AP:
  • Available: The GPS has locked on sufficient satellites to determine the coordinates of the AP. The GPS locks within 2 minutes if the AP is exposed to open sky. If not, the time is unpredictable, depending on signal obstructions.
  • Not Available: The initial state after the AP powers up.
The AFC Spectrum Mismatch graph highlights the number of APs with discrepancies between their expected AFC settings and the actual spectrum usage.
Hover over the graph colors to see the percentage for each individual status.
Device List Details
The Device List displays the following AFC Wireless view columns by default:
  • Status
  • Host Name
  • Network Policy
  • Managed By
  • Uptime
  • MGT IPAddress
  • Clients
  • Location
  • Site
  • Serial #
  • Model
  • Managed
  • Country
  • Geo Location
  • WiFi Radio
  • AFC Status
  • Expire
  • Power Mode
  • Channel
  • Req. Channel
  • Power
  • Req. Power
See Device List Columns for column information descriptions.
Management Tools
Choose from the following actions:
