View Antenna Patterns
Antenna Patterns allow users to visualize the coverage and performance of devices on the heat map. This is essential for optimizing network design and troubleshooting connectivity issues.
The antenna patterns display how the antenna radiates energy in different directions and frequencies, including:
  • Azimuth Plane: A top-down view of the antenna's radiation pattern, illustrating how the signal spreads out horizontally. It helps in understanding the coverage area and signal strength in different directions around the device.
  • Elevation Plane: A side view of the antenna's radiation pattern, illustrating how the signal spreads out vertically. It helps in understanding the coverage area and signal strength above and below the device.
  • Frequency Band: Along with Azimuth and Elevation planes, displays the antenna's radiation pattern for the 2.4 GHz, 5 GHz, and 6 GHz frequency bands for wireless devices.
These patterns help network administrators visualize and optimize device placement to ensure even and effective coverage.
Use this task to view antenna patterns.
  1. Go to Manage > Real time maps.
  2. Select a floor from the location list.
    The selected floor must include a floor map. For more information, see Add a Floor Plan.
  3. Select the icon.
    You can use the Search field to find a specific device if your device list is long.
  4. Select a device tab.
