Configure AP Radio and Power Settings
  1. Go to Manage > Real Time Maps.
  2. From the Global View location list, select a floor or use the Search field to search for a specific site, building, or floor.
    The Search field helps you find a specific location in a large network. Enter the first few characters to see a list of locations. The more characters you enter, the more precise the search results will be.
    The selected floor must include a floor plan. For more information, see Add a Floor Plan.
  3. Select a connected device from the floor plan, and then select the Actions tab.
  4. Select Radio & Power configuration.
  5. Select the Wi-Fi interface, configure the radio and power settings, and then select Apply.
    Table 1. Radio and Power Configuration Settings
    FieldDescription
    Radio StatusToggle to turn on/off the Radio Status.
    ChannelSelect a specific channel. Select Auto to have ExtremeCloud‌ IQ select the channel.
    Transmission PowerSet the transmission power for the selected device (1 to 20 dBm). Select Auto to have ExtremeCloud‌ IQ select the transmission power.
