aggregation
interface-config-radio-instance
Configures frame aggregation parameters. Frame aggregation is a IEEE 802.11e, 802.11n, and 802.11ac wireless networking standard. It increases throughput by sending two or more data frames in a single transmission. There are two types of frame aggregation: Aggregate - MAC Service Data Unit (A-MSDU ) aggregation and Aggregate - MAC Protocol Data Unit (A-MPDU ) aggregation. Both modes group several data frames into one large data frame.
  • Access Points — AP505i, AP510i, AP510e, AP560i, AP6522, AP6562, AP7161, AP7502, AP7522, AP7532, AP7562, AP7602, AP7612, AP7622, AP763, AP7662, AP8163, AP8543, AP8533
Syntax
aggregation [ampdu|amsdu]
aggregation ampdu [rx-only|tx-only|tx-rx|none|max-aggr-size|min-spacing|
min-spacing]
aggregation ampdu [rx-only|tx-only|tx-rx|none]
aggregation ampdu max-aggr-size [rx|tx]
aggregation ampdu max-aggr-size rx [8191|16383|32767|65535|128000|256000|
512000|1024000|default]
aggregation ampdu max-aggr-size tx <2000-1024000>
aggregation ampdu min-spacing [0|1|2|4|8|16|auto]
aggregation amsdu [rx-only|tx-rx]
Parameters
aggregation Configures 802.11n frame aggregation parameters
ampdu Configures AMPDU (Aggregate MAC Protocol Data Unit) frame aggregation parameters
AMPDU aggregation joins multiple MPDU frames, addressed to a single destination, to form a single frame. It wraps each MPDU frame in a MAC header. This aggregation mode is less efficient, but more reliable in environments with high error rates. It enables the acknowledgment and retransmission of each aggregated data frame individually.
tx-only Supports the transmission of AMPDU aggregated frames only
rx-only Supports the receipt of AMPDU aggregated frames only
tx-rx Supports the transmission and receipt of AMPDU aggregated frames (default setting)
none Disables support for AMPDU aggregation
ampdu Configures AMPDU frame aggregation parameters
max-aggr-size Configures AMPDU packet size limits. Configure the packet size limit for transmitted and received packets.
rx [8191|16383|32767|65535|128000|256000|512000| 1024000] Configures the maximum limit (in bytes) advertised for received frame size
  • 8191 – Advertises a maximum frame size of 8191 bytes
  • 16383 – Advertises a maximum frame size of 16383 bytes
  • 32767 – Advertises a maximum frame size of 32767 bytes
  • 65535 – Advertises a maximum frame size of 65535 bytes
  • 128000 – Advertises a maximum frame size of 128000 bytes
  • 256000 – Advertises a maximum frame size of 256000 bytes
  • 512000 – Advertises a maximum frame size of 512000 bytes
  • 1024000 – Advertises a maximum frame size of 1024000 bytes (default setting)
  • default - Sets the default aggregation size.
tx <2000-1024000> Configures the maximum size (in bytes) for AMPDU aggregated transmitted frame size
  • <2000-1024000> – Sets the maximum aggregated transmitted frame size limit
    The available range depends on the AP type and the radio selected.
    For 802.11ac capable APs, the range is as follows:
    • radio 1 - 2000 - 65,535 bytes. The default value is 65,535 bytes.
    • radio 2 - The range is 2000 - 1,024,000 bytes. The default value is 1,024,000 bytes.
      Note:
      For AP7662 and AP7632 models the range for radio 1 and radio 2 is 2000 - 1,024,000 bytes. And the default is 1,024,000 bytes.
    Note: The WiNG 802.11ac capable APs are: AP505, AP510, AP7522, AP7532, AP7562, AP7602, AP7612, AP7632, AP7662, AP8432, and AP8533.
    For non 802.11ac APs the range is as follows:
    • radio 1 and radio 2 - 2000 - 65,535 bytes. The default value is 65,535 bytes.
min-spacing [0|1|2|4|8|16] Configures the minimum gap, in microseconds, between AMPDU frames
  • 0 – Configures the minimum gap as 0 microseconds
  • 1 – Configures the minimum gap as 1 microseconds
  • 2 – Configures the minimum gap as 2 microseconds
  • 4 – Configures the minimum gap as 4 microseconds
  • 8 – Configures the minimum gap as 8 microseconds
  • 16 – Configures the minimum gap as 16 microseconds
  • auto – Auto configures the minimum gap depending on the platform and radio type (default setting)
amsdu Configures AMSDU (Aggregated MAC Service Data Unit) frame aggregation parameters. AMSDU aggregation collects Ethernet frames addressed to a single destination. But, unlike AMPDU, it wraps all frames in a single 802.11n frame.
rx-only Supports the receipt of AMSDU aggregated frames only (default setting)
tx-rx Supports the transmission and receipt of AMSDU aggregated frames
nx9500-6C8809(config-profile-505TestProfile-if-radio1)#aggregation ampdu tx-only
nx9500-6C8809(config-profile-505TestProfile-if-radio1)#show context
 interface radio1
  aeroscout forward
Related Commands
no (radio-interface-config-command) Disables 802.11n aggregation parameters
