interface-config-radio-instance
Configures an antenna's elevation gain. Antenna gain is the ratio of an antenna's radiation intensity in a given direction to the intensity produced by a no-loss, isotropic antenna radiating equally in all directions. An antenna's gain along the horizon and at an elevation of 30 degree may vary. The elevation gain is defined as the maximum antenna gain at 30 to 150 degrees above the horizon. If elevation gain is configured, the transmit (TX) power calculations maximize the allowable TX power for an elevation below 30 degree.
Access points must conform to U.S. FCC (Federal Communications Commission's) limitations. FCC has now stipulated a 21dBm EIRP (Effective Isotropic Radiated Power) limit for power directed 30 degrees above the horizon.
For Extreme Networks -supplied antennas, compatible with 5.0 GHz on the AP7562 access point, refer to the Antenna Guide for "Elevation Gain" information. If using a third-party antenna, it is required that you obtain the antenna-elevation gain information from the antenna manufacturer.
The elevation gain should be configured if the access point:
Professional installers must complete the following steps to ensure compliance with the FCC rule:
ap7562-80C2AC(config-device-84-24-8D-80-C2-AC-if-radio2)#service antenna-type dipole
ap7562-80C2AC(config-device-84-24-8D-80-C2-AC-if-radio2)#antenna-gain 7.0
ap7562-80C2AC(config-device-84-24-8D-80-C2-AC-if-radio2)#placement outdoor
ap7562-80C2AC(config-device-84-24-8D-80-C2-AC-if-radio2)#antenna-elevation 5.0
After the professional installer enters the antenna type, gain, placement, and elevation gain using the CLI as outlined above, the firmware will use this information and hardcoded maximum limits determined during testing (See Annex C in FCC Report #FR4D0448AB) to limit the EIRP below 21dBm for outdoor use in UNII-1 band. The antenna information is provided in the Installation guide and antenna guide.
antenna-elevation <-30.0-36.0>
The antenna elevation gain feature is supported only on the AP7562 model access point.antenna-elevation <-30.0-36.0>
antenna-elevation <-30.0-36.0> | Configures the
antenna elevation gain from -30.0 - 36.0 dB. Refer to the antenna
specifications for antenna-elevation gain information. The default value is 0 dB. |
ap505-133E1C(config-profile-testap505-if-radio2)#antenna-elevation 5.0 ap505-133E1C(config-profile-testap505-if-radio2)#show context interface radio2 mesh client antenna-elevation 5.0 aggregation ampdu tx-only aeroscout forward ip 1.23.4.56 port 300 antenna-diversity ap505-133E1C(config-profile-testap505-if-radio2)#
no (radio-interface-config-command) | Resets antenna elevation gain to default (0 dB) |
