BGP route maps are used to control and modify routing information. A BGP route map is a collection of deny and/or permit route rules that define and control redistribution of routes between routers and routing processes. Each rule consists of match criteria and set lines. If a route matches a criteria, the corresponding set line is applied, and the route is passed to the BGP table or to the neighbor, depending on whether the route map is set for incoming or outgoing route updates.
Use the (config) instance to configure BGP route map related parameters.
<DEVICE>(config)#route-map <ROUTE-MAP-NAME>
<DEVICE>(config)#route-map test <DEVICE>(config-dr-route-map-test)#? Route Map Mode commands: deny Add a deny route map rule to deny set operations no Negate a command or set its defaults permit Add a permit route map rule to permit set operations clrscr Clears the display screen commit Commit all changes made in this session do Run commands from Exec mode end End current mode and change to EXEC mode exit End current mode and down to previous mode help Description of the interactive help system revert Revert changes service Service Commands show Show running system information write Write running configuration to memory or terminal <DEVICE>(config-dr-route-map-test)#
<DEVICE>(config-dr-route-map-test)#deny route-map <1-65535>
<DEVICE>(config-dr-route-map-test)#permit route-map <1-65535>
<DEVICE>(config-dr-route-map-test)#permit route-map 1
<DEVICE>(config-dr-route-map-test)#deny route-map 2
<DEVICE>(config-dr-route-map-test)#show context route-map test permit route-map 1 deny route-map 2 <DEVICE>(config-dr-route-map-test)#
<DEVICE>(config-dr-route-map-test-dr-route-map-rule-1)#? Route Map Rule Mode commands: description Configure comment for this route map match Match values from routing table no Negate a command or set its defaults set Set values in destination routing protocol clrscr Clears the display screen commit Commit all changes made in this session do Run commands from Exec mode end End current mode and change to EXEC mode exit End current mode and down to previous mode help Description of the interactive help system revert Revert changes service Service Commands show Show running system information write Write running configuration to memory or terminal <DEVICE>(config-dr-route-map-test-dr-route-map-rule-1)#
BGP-Route-Map Config Mode Commands
Print
this page
Email this topic
Feedback
