Installing TPVM
The TPVM package is available separately from the SLX-OS software, and may be downloaded from the SLX-OS Release Server. This decoupling enables faster turnaround on enhancements and bug fixes, while reducing the file size of the SLX-OS distribution. (Prior to SLX-OS 18r.2.00, the TPVM package was released in conjunction with the SLX-OS packages.)
Important
Important
The installation is disruptive, and any data saved on the TPVM partition is erased. You must save any data manually before executing the tpvm install command.
Please also note:
The following table lists the TPVM package names and locations for relevant SLX-OS releases.
Table 1. TPVM package names and locations for relevant SLX-OS releases
SLX-OS release TPVM package name TPVM package location
slxos16r.x.xx vm-swbd2900-1.0.0-1.i386.deb <slxos release dir>/SWBD2900/vm-swbd2900-1.0.0-1.i386.deb
slxos17r.1.xx vm-swbd2900-1.0.0-1.i386.deb <slxos release dir>/SWBD2900/vm-swbd2900-1.0.0-1.i386.deb
slxos17r.2.xx vm-swbd2900-1.0.0-1.amd64.deb <slxos release dir>/SWBD2900/vm-swbd2900-1.0.0-1.amd64.deb
slxos18r.1.xx vm-swbd2900-1.0.0-1.amd64.deb <slxos release dir>/SWBD2900/vm-swbd2900-1.0.0-1.amd64.deb
slxos18r.2.xx tpvm-2.0.0-0.amd64.deb <TPVM release url>/tpvm2.0.0/tpvm-2.0.0-0.amd64.deb (see NOTE)
slxos 20.1.xx tpvm-3.0.0-0.amd64.deb <TPVM release url>/tpvm3.0.0/tpvm-3.0.0-0.amd64.deb
Removed from SLX-OS release folder and posted on release server for access through separate URL.
