Use the following procedures to configure the Insight Interface TVPM endpoint for Analytic Mirroring. The following procedure assumes that the TVPM license is installed and active, and that TVPM is installed. Use Linux commands to configure a Layer 3 IP address and route for the ethernet interface.
device# tvpm start
Eth1 to promiscuous mode.
				bash# ifconfig eth1 promiscuous bash# tcpdump -i eth1
device(config)# interface port-channel 20
device(config-Port-channel-20)# insight enable
device(config-Port-channel-20)# no shutdown
device(config)# monitor session 1 device (config-session-1)# source ethernet 0/49 destination port-channel 20 direction both
