Use the following procedures to configure the Insight Interface TVPM endpoint for Switching. The following procedure assumes that the TVPM license is installed and active, and that TVPM is installed. Use Linux commands to configure a Layer 3 IP address and route for the ethernet interface.
  1. Start TVPM.
    device# tvpm start
  2. From a LINUX prompt, configure the IPV4 address and route entry.
    bash# ifconfig eth1 10.0.0.100 netmask 255.255.255.0
    bash# route add -net 1.1.1.0 netmask 255.255.255.0 gw 10.0.0.1
  3. In global configuration mode, specify a port-channel. You can create a new port-channel or use an existing unconfigured port-channel. The Insight Interface can only be configured on one port-channel
    device(config)# interface port-channel 20
  4. In interface subtype configuration mode, enter the insight enable command.
    device(config-Port-channel-20)# insight enable
  5. Perform the following configuration:
    SLX# conf t
    Entering configuration mode terminal
    SLX(config)# vlan 100
    SLX(config-vlan-100)# router-interface ve 100
    SLX(config-vlan-100)# exit
    SLX(config)# interface ve 100
    SLX(config-if-Ve-100)# ip address 10.0.0.1/24
    SLX(config-if-Ve-100)# no shut
    SLX(config-if-Ve-100)# exit
    SLX(config)# interface port-channel 20
    SLX(config-Port-channel-20)# switchport
    SLX(config-Port-channel-20)# switchport mode access
    SLX(config-Port-channel-20)# switchport access vlan 100
    SLX(config-Port-channel-20)# no shutdown
