TCAM profiles
TCAM profiles enable you to optimize TCAM resources according to your system requirements.
TCAM profiles other than default are supported only on devices based on the DNX chipset family. For a list of such devices, see "Supported Hardware".
TCAM is used by various forwarding applications. A TCAM profile supports a specified group of forwarding applications.
The following TCAM profiles are supported:
TCAM Profile Scaling (DNX Devices)
For devices based on the DNX chipset-family, the following table displays maximum TCAM entries by features and TCAM profile.
TCAM-entries available per profile (DNX devices)
* For shared limits, the TCAM is filled using first-come first-served.
** DB is shared with L2 and L3 control protocol features.
NS = not supported.
RL = rate limiting.
BD = bridge domain.
Default TCAM Profile (XGS Devices)
For devices based on the XGS chipset-family, the following table displays maximum TCAM entries by features. The only TCAM profile supported is default.
Maximum TCAM entries by features
** DB is shared with L2 ctrl protocol, L3 protocol, and so forth.
NS = not supported.
RL = rate limiting.
BD = bridge domain.
