The configuration rollback feature provides the capability to take a checkpoint or snapshot of the current running configuration on the device and revert the current running configuration to a checkpoint configuration at a later stage, without the need to reboot the device.
This functionality can be used to revert to a previous configuration state, effectively rolling back any configuration changes that were made since that configuration checkpoint was created. Administrators can create multiple checkpoints to save different versions of the running configuration.
Supported topologies
The following IP Clos and non-Clos rack topologies are supported.
3-tier IP Clos topology
5-tier IP Clos topology
Non-Clos 4-rack topology
