If the root account is disabled and SLX-OS CLI is not available, to recover the VM root password first recover the VM root login account.
For a list of the currently supported XGS devices, see the "Supported Hardware" topic.
  1. Enter the reboot command.
  2. Select and enter the ONIE option.
  3. Select and enter the ONIE: Rescue option.
  4. Define the root login value for the root recover environment variable.
    ONIE:/ # bootenv VM_Root_Recover RootLogin
  5. Enter the reboot command.
    ONIE:/ # reboot
    ONIE:/ # discover: Rescue mode detected. No discover stopped.
    Stopping: dropbear ssh daemon... done.
    The root account is now enabled. You can log in with the default password.
  6. If the SLX-OS CLI is available, you can recover the root account by using the SLX-OS CLI root enable command.
