With admin-level permissions, you can access the SLXVM Linux shell from the SLX-OS CLI, by using the start-shell command.
Inside the SLXVM Linux shell, you can execute commands that do not require root permissions. To escalate your permissions, refer to "Escalating Linux permissions to root".
  1. To access the SLXVM Linux shell, enter the start-shell command.
    device# start-shell
    Entering Linux shell for the user: admUser
    [admUser@SLX]#
  2. Enter Linux commands and run scripts as needed. You can also run SLX-OS commands from the Linux shell.
  3. To exit the shell and return to the SLX-OS CLI, enter exit.
    [admUser@SLX]# exit
    Upon exiting, the following message appears and you return to the SLX-OS CLI prompt.
    exit
    Exited from Linux shell
    device#
