SLX-OS VM commands
Use these commands on the SLX platform to help troubleshoot the VM.
Display general interface information
device# show interface stats brief
                 Packets        Error        Discards     CRC
Interface      rx       tx   rx        tx  rx        tx   rx
Po  1          16        2    0         0   0          0   0
Eth  0/1        0        0    0         0   0          0   0
Eth  0/125      8        3    0         0   0          0   0
Display port-channel information
device# show interface port-channel 1
Port-channel 1 is up, line protocol is up
Hardware is AGGREGATE, address is 748e.f88f.5ffd
   Current address is 748e.f88f.5ffd
Description: Insight port-channel
Interface index (ifindex) is 671088641
Minimum number of links to bring Port-channel up is 1
MTU 2500 bytes
LineSpeed Actual     : 10000 Mbit
Allowed Member Speed : 10000 Mbit
Priority Tag disable
IPv6 RA Guard disable
Last clearing of show interface counters: 03:43:52
Queueing strategy: fifo
Receive Statistics:
    0 packets, 0 bytes
    Unicasts: 0, Multicasts: 0, Broadcasts: 0
    64-byte pkts: 0, Over 64-byte pkts: 0, Over 127-byte pkts: 0
    Over 255-byte pkts: 0, Over 511-byte pkts: 0, Over 1023-byte pkts: 0
    Over 1518-byte pkts(Jumbo): 0
    Runts: 0, Jabbers: 0, CRC: 0, Overruns: 0
    Errors: 0, Discards: 0
Transmit Statistics:
    0 packets, 0 bytes
    Underruns: 0
Rate info:
    Input 0.000000 Mbits/sec, 0 packets/sec, 0.00% of line-rate
    Output 0.000000 Mbits/sec, 0 packets/sec, 0.00% of line-rate
Time since last interface status change: 03:43:52
device# show running-config interface port-channel 1
interface Port-channel 1
 no vlag ignore-split
 description Insight port on MM1
 no shutdown
device# show port-channel
 Static Aggregator: Po 1
 Aggregator type: Standard
    Eth 0/125
Optional keywords are summary, detail, and load-balance.
Display Ethernet interface information
device# show interface ethernet 0/125
Ethernet 0/125 is up, line protocol is down (link protocol down)
Hardware is Ethernet, address is 0027.f817.12fe
    Current address is 0027.f817.12fe
Pluggable media not present
Interface index (ifindex) is 4704206921
MTU 2500 bytes
LineSpeed Actual     : Nil
LineSpeed Configured : Auto, Duplex: Full
Last clearing of show interface counters: 03:46:22
Receive Statistics:
    0 packets, 0 bytes
    0 packets, 0 bytes
    Underruns: 0
Rate info:
Time since last interface status change: 03:46:22
