From the SLXVM Linux shell, you can execute a single SLX-OS command or a file that contains a series of such commands.
[admUser@SLX]# cli_run -c "show ip interface brief" | grep Port-channel > /tmp/interface
[admUser@SLX]# cat /tmp/interface Port-channel 1 unassigned administratively down down Port-channel 2 unassigned administratively down down
[admUser@SLX]# cli_run -f /tmp/slxcli_cmd_file > /tmp/newfile
[admUser@SLX]# cat /tmp/slxcli_cmd_file show ssh server status conf t router bgp local-as 23 capability as4-enable
Make sure that each command is on a new line.[admUser@SLX]# cat /tmp/newfile Welcome to the Extreme SLX-OS Software admin connected from 127.0.0.1 using console on SLX SLX# show ssh server status | nomore VRF-Name: mgmt-vrf Status: Enabled VRF-Name: default-vrf Status: Enabled device# conf t Entering configuration mode terminal Current configuration users: admin console (cli from 10.70.4.183) on since 2017-01-31 05:49:59 terminal mode device(config)# router bgp device(config-bgp-router)# local-as 23 device(config-bgp-router)# capability as4-enable device(config-bgp-router)#
