Using the tpvm config Command
The tpvm config command is available at the SLX-OS CLI on a device.
The tpvm config command, in privileged EXEC mode, allows you to customize the following TPVM optional features:
  • tpvm config ldap: LDAP configurations for TPVM
  • tpvm config dns: DNS configurations for TPVM
  • tpvm config ntp: NTP configurations for TPVM
tpvm config ldap
This section describes the commands used to configure LDAP over TPVM.
tpvm config dns
This section describes the commands used to configure DNS over TPVM.
tpvm config ntp
This section describes the commands used to configure NTP over TPVM.
Show Commands
This section describes the show commands used with tpvm config.
