When you make a backup copy of a configuration file on an attached USB device, specify the USB and the destination file name on the USB device. You do not need to specify the target directory. The file is automatically recognized as a configuration file and stored in the default configuration directory.
  1. Enable the USB device.
    device# usb on
    USB storage enabled
  2. Enter the copy startup-config command with the destination (USB) and file name.
    device# copy startup-config usb://startup-config_slx-08_20160510
