Auto-Persistence of Configuration
Data
All configurations performed on the device are automatically persisted. You do not need to
perform copy running-config startup-config explicitly to persist the
configuration.
Configurations are saved to a persistent configuration datastore. During device bring-up,
configurations are replayed from this datastore. If the datastore becomes unusable for
any reason, configurations are replayed from a startup-file.
By default, the startup-file has the factory-default configuration. This startup-file is
updated with datastore entries whenever user executes copy running-config
startup-config.
Configuration Replay during Device Boot
By default, configurations are replayed from the datastore when the device boots up.
However, after the execution of either of the below operations (and reboot),
configurations will be replayed from the startup-file instead of the database.
- copy default-config startup-config
- Copy <tftp:/scp:/ftp:/usb:/flash:>/<file>
startup-config
Upgrade and Downgrade Considerations
Before a firmware upgrade or downgrade, it is mandatory to execute copy
running-config startup-config. This will ensure that the startup-file
is in sync with the configuration datastore.
Command Information
The following examples illustrate how to display the default, startup, and running
configurations.
- Displaying the Default Configuration:
To display the default
configuration, enter
show file with the default
configuration filename, in privileged EXEC mode.
(device)# show file defaultconfig.standalone
- Displaying the Startup Configuration
To display the contents of the
startup configuration, enter
show startup-config, in
privileged EXEC
mode.
(device)# show startup-config
- Displaying the Running Configuration
running configuration, enter
show running-config in
privileged EXEC
mode.
(device)# show running-config
The show startup-database
command has been deprecated.
