Port management
	 The Extreme device allows the port management of
			the following features for interface Ethernet ports.
				-  SLX 9540 port
					management includes the following:
						-  Supports 54 ports in total.
							Ports 1 - 48 support 10G, 1G and 100 Mbps speed (default is10G).
						-  Ports 49-54 support 40G, 100G;
							and also support 4x10G and 4x25G breakout configurations. Default is
							100G.
						- Forward Error Correction (FEC)
							is supported only in 100G mode.
					SLX 9640 port management includes the following:
						-  Supports 36 ports in total. Ports 1 - 24 support 10G and 1G speed
							(default is10G).
						-  Ports 25-36 support 40G, 100G; and also support 4x10G, 4x25G, and 2x50G
							breakout configurations. Default is 100G.
						- Forward Error Correction (FEC) is supported only in 100G mode.
				- SLX-9250 port management includes the following:
						- Supports 32 ports of 40G and 100G.
						- Ports may be broken out into 4x10G or 4x25G.
				- SLX-9150-48Y port management includes the following:
						- Supports 56 ports in total
						- 48 ports support 1G, 10G, and 25G.
						- 8 ports support  40G, and 100G. These ports are able to break out to
							4x10G.
						- 4x25Gb is supported on 2 ports only (0/49 and 0/56).
				- 9150-48XT port management includes the following:
						- 48 ports support 1G and 10G.
						- 6 ports support 40G and 100G.
						- Ports 49 and 54 support break out configurations of 4x10G or 4x25G.
				- Interface Ethernet port management
					features discussed this section include the following:
						-  Port transition hold timer
						-  Port flap dampening
						- Link fault signaling
