Displaying device interfaces
The device supports Ethernet, loopback, management, and virtual Ethernet interfaces (VEs).
Enter the show running-config interface command to display the interfaces and their status.
The following example displays the Ethernet interfaces on the device and are identified by the port number.
For example, the notation 0/8 indicates port 8 on a device.
device# show running-config interface ethernet
interface Ethernet 0/1
 no shutdown
interface Ethernet 0/2
 channel-group 101 mode active type standard
 lacp timeout long
 no shutdown
interface Ethernet 0/3
 lacp timeout short
 no shutdown
interface Ethernet 0/4
 shutdown
interface Ethernet 0/5
 shutdown
interface Ethernet 0/6
 shutdown
interface Ethernet 0/8
 channel-group 143 mode active type standard
 lacp timeout short
 no shutdown
interface Ethernet 0/9
 shutdown
