SLX-OS CLI to VM access
The SLX-OS CLI allows you to access to the SLXVM shell by using the start-shell command.
When you log into the SLX-OS CLI, you can use the default admin or user credentials. Non-default users are authenticated through AAA.
The following example shows Telnet access to the SLX-OS CLI with admin credentials.
client# telnet 10.24.12.71
Trying 10.24.12.71...
Connected to 10.24.12.71.
Escape character is '^]'.
SLX login: admin
Password:
SECURITY WARNING: The default password for at least
one default account (root, admin and user) have not been changed.
Welcome to the Extreme SLX Operating System Software
admin connected from 10.70.5.113 using telnet on device
device#
The default SLX-OS prompt is SLX#. However, throughout this guide, the device# is used as the prompt.
To exit the session, enter exit.
