The following table includes description of changes in this document for the 20.2.1a release.
| Feature | Description | Described in |
Auto persistence |
Configuration data automatically persists in a single database and is replayed when the system reboots. |
Maintenance mode |
The config-system-maintenance command provides the enable-on-reboot parameter, allowing the device to enter maintenance mode upon reboot. Use of this command does not disturb the current operation of the device. |
Redundant management |
The Redundant Management Interface feature provides fault tolerance for the management path. |
NTP |
NTP Server command reconfiguration after SLX-OS downgrade. |
