Accessing the SLXVM1 Host-OS shell from the SLX-OS CLI
You can access the SLXVM1 host-OS shell from the SLX-OS CLI from an SSH session.
In the following example, an SSH session is used to access the SLXVM1 host-OS shell.
device# ssh SLXVM1_kvm vrf mgmt-vrf -l root
The authenticity of host 'SLXVM1_kvm (127.2.0.1)' can't be established.
ECDSA key fingerprint is d5:ba:cc:d4:57:03:e4:b2:6f:ca:d2:dd:4c:40:5d:60.
Are you sure you want to continue connecting (yes/no)? yes
Warning: Permanently added 'SLXVM1_kvm' (ECDSA) to the list of known hosts.
root@SLXVM1_kvm's password:
Welcome to Ubuntu 14.04 LTS (GNU/Linux 3.14.17 x86_64)
 * Documentation:  https://help.ubuntu.com/
  System information as of Thu Aug  4 10:41:47 PDT 2016
  System load:  0.81              Users logged in:       0
  Usage of /:   14.7% of 9.72GB   IP address for eth1:   127.2.0.1
  Memory usage: 54%               IP address for br0:    10.24.12.77
  Swap usage:   0%                IP address for virbr0: 192.168.122.1
  Processes:    164
  Graph this data and manage this system at:
    https://landscape.canonical.com/
Last login: Thu Aug  4 10:41:47 2016 from cp0_vm1
root@HOST:~#
In the previous examples, use exit to terminate the session and return back to the parent shell.
