You can use the Telnet service to connect to the Extreme device.
client# telnet 10.17.37.157
If the device is active and the Telnet service is enabled on it, a display similar to the following appears.
Trying 10.17.37.157... Connected to 10.17.37.157. Escape character is '^]'.
device login: admin Password: SECURITY WARNING: The default password for at least one default account (root, admin and user) have not been changed. Welcome to the Extreme SLX-OS Software admin connected from 10.252.24.5 using telnet on device device#
The default admin login name is admin. The default user name is user. The default password for both admin and user accounts is password.Extreme recommends that you change the default account password when you log in for the first time. For more information on changing the default password, refer to the Extreme SLX-OS Security Configuration Guide.
