ExtremeCloud‌ IQ (Classic) Configuration Example (Alternative Flow)
The following image illustrates a sample topology for a redundant Tunnel Concentrator deployment where ExtremeCloud IQ (Classic) is the management application. This deployment includes redundant tunnels with each tunnel leading to a Tunnel Concentrator service that includes an HA pair of instances.
Redundant Tunnel Concentrator Configuration Example for ExtremeCloud IQ
Table 1. Address Settings and Where they Get Assigned
Universal Compute Platform ExtremeCloud IQ
Hostname IP Address Tunnel Conc. Instance Tunnel Conc. Service Tunnel IP Address (VRRP) IP Address (tunnel termination) Role in HA Pair (per instance) Tunnel Role in User Profile (per service)
UCP_01 10.10.10.1 TC_01 TC_Svc_01 10.10.10.40 10.10.10.4 Primary Primary
UCP_02 10.10.10.60 TC_02 10.10.10.62 Backup
UCP_03 10.10.10.181 TC_03 TC_Svc_02 10.10.10.212 10.10.10.182 Primary Secondary
UCP_04 10.10.10.201 TC_04 10.10.10.202 Backup
Configuration Flow
This example uses an alternative configuration flow that differs from the configuration that is presented in the ExtremeCloud IQ (Classic) Configuration chapter. Because the configuration example does not use Layer 2 roaming or a tunnel policy, you can complete the configuration from the network policy by drilling down into multiple configuration layers, assigning settings, and then reversing out, while saving the configuration in the reverse order from which it was applied.
The following image illustrates the configuration flow for this example.
Tunnel Concentrator Configuration using Network Policy (ExtremeCloud IQ)
Requirements and Assumptions
Before you start configuration, note the following:
  • You need four new Tunnel Concentrator installations that are installed on different appliances, but which are not onboarded to ExtremeCloud IQ. For this example, assume that the four Serial Numbers are: TC_01, TC_02, TC_03, and TC_04.
  • You need existing Network Policy and SSID configurations in place on ExtremeCloud IQ so that you can add Tunnel Concentrator settings to these configuration elements. This example uses Sample_Network and Sample_SSID as the existing configurations.
  • The example assumes that you want to configure a new user profile and a new Tunnel Concentrator service. However, you have the option to edit existing configurations.
  • The example assumes that you are not using a tunnel policy and are not configuring Layer 2 roaming.
Configuration
The configuration consists of two main stages:
  • Tunnel Concentrator onboarding to ExtremeCloud IQ
  • Network Policy configuration and deployment
Tunnel Concentrator Onboarding to ExtremeCloud IQ
Use the Quick Add Devices option to onboard all Tunnel Concentrator installations to ExtremeCloud IQ using the Serial Numbers.
  1. On ExtremeCloud IQ (Classic), go to Manage > Devices.
  2. Select (Add) and then Quick Add Devices > Manage your devices directly from the cloud.
  3. In the Serial Number field, enter each Tunnel Concentrator serial number, separated by a comma.
    Quick Add Tunnel Concentrators to ExtremeCloud IQ
  4. From the Policy drop-down, select the network policy.
  5. Select Add Devices.
    Each device gets onboarded to ExtremeCloud IQ, and gets assigned to your network policy.
Network Policy Configuration and Deployment
The remaining configuration can be completed from the Network Policy configuration.
  1. Go to Configure > Network Policies and select your network policy. For example, Sample_Network.
    Select your Network Policy
  2. Select 2 Wireless.
  3. Select the SSID to which you want to apply Tunnel Concentrator settings. For example, Sample_SSID.
    Select the SSID that will use Tunnel Concentrator
  4. Under User Access Settings, and for the Default User Profile, select the adjacent to create a new default user profile to hold the Tunnel Concentrator settings.
    Assign Default User Profile to SSID
    • In this example, you are creating a new user profile. However, you can also select and edit an existing profile.
    • To assign your user profile as non-default profile, select Apply a different user profile to various clients and groups, then select or create the user profile. Next, configure assignment rules to determine when the non-default profile gets applied instead of the default profile
  5. For the newly created user profile, configure the following settings.
    1. Enter a Name for the new profile. For example, Sample_User_Profile.
    2. For Connect to, select VLAN and assign a VLAN ID. For example, 1530.
      Create a New User Profile
    3. Select the Traffic Tunneling tab and toggle Traffic Tunneling (GRE) to ON.
      If you have an existing tunnel policy that points to a Tunnel Concentrator service, you can reuse that policy's Tunnel Concentrator settings in the user profile. Select Re-use Tunnel Policy and select the policy. The Tunnel Concentrator service from the policy gets assigned as Tunnel Destination in the user profile.
    4. Select Tunnel Concentrator and then configure the tunnel destination with primary and secondary tunnels.
      1. For Primary, select the adjacent to create a new Tunnel Concentrator service to act as primary tunnel destination for this profile.
        Assign Tunneling to New User Profile
      2. In the New Tunnel Concentrator Service window, assign the following settings:
        For Tunnel Concentrator Service:
        • Name=TC_Svc_01
        • Redundant Tunnel Concentrator
        • Tunnel IP Address/CIDR=10.10.10.40/24
        • VRRP Router ID=1
        • Native VLAN ID=1530
        For Primary Tunnel Concentrator:
        • Device Tunnel Concentrator=TC_01
        • Tunnel Port=Port 1
        • VLAN ID= 15
        • IP Address=10.10.10.4
        • Bridge Port=Port 3
        For Backup Tunnel Concentrator:
        • Device Tunnel Concentrator=TC_02
        • VLAN ID=15
        • IP Address=10.10.10.62
        Leave the keepalive settings at their default values.
        Configure New Redundant Tunnel Concentrator Service
      3. Select Save to save the new Tunnel Concentrator service.
        The new Tunnel Concentrator service displays as Primary tunnel destination within the User Profile configuration.
        New Tunnel Destination for User Profile
      4. For Secondary, select the adjacent and create the secondary Tunnel Concentrator service using the TC_03 and TC_04 instances and the addressing from Redundant Tunnel Concentrator Configuration Example for ExtremeCloud IQ.
    5. Once the Primary and Secondary tunnel destinations are assigned, select Save User Profile.
      The new user profile with the Tunnel Concentrator settings displays as Default User Profile within the SSID configuration. The VLAN from the user profile is the default VLAN for the SSID.
      New Default User Profile for SSID
  6. Select Save to save the SSID configuration.
  7. Deploy the network policy to affected APs and Tunnel Concentrators using a delta push.
