Use this procedure to add new Tunnel Concentrator
device instances to Extreme Platform ONE Networking.
Log in to Extreme Platform ONE Networking.
Go to Monitoring > Network Devices.
Select Add Devices
and then select Manually.
Select Managed by
Cloud.
For Device Type,
select Tunnel
Concentrator.
Enter the Serial Number of the Tunnel
Concentrator instance. If you have multiple instances to add, select to add
extra lines where you can enter the additional serial numbers (up to a maximum
of ten).
Select a License
Level. The default is Automatic.
Optional. Assign a Network
Policy.
Optional. Assign a Location.
Select Add
Device(s).
If you do not have a Network Policy configured, you can skip
the step for assigning a Network Policy and assign the policy later.
