Deploy Network Policy
Use this procedure on Extreme Platform ONE Networking after your Tunnel Concentrator configuration is fully configured within a Network Policy to deploy the updated policy to affected devices.
  1. Go to Configuration > Network Policies and select the appropriate policy.
  2. Select 4 Deploy Policy.
  3. Select the devices to which you want to upload the policy.
    • To automatically select the check boxes for all of the devices, select the check box in the top left of the table header.
    • To upload your network policy to specific devices only, select the corresponding check boxes for those devices.
    Use the Assigned, Eligible, and Filtered controls to customize your view of the devices that appear in the table.
  4. Select UPLOAD.
  5. In the Device Update window, select the type of update (Delta or Complete), whether to update IQ Engine and Extreme Networks switch images, and the activation times for the updated devices.
  6. Select Enable Distributed Image Upgrade when WAN speed and traffic usage are concerns.
    Select this option to revert the switch configuration if the device update causes a disconnect between the switch and Extreme Platform ONE Networking. The switch reboots and reverts to its previous configuration, which enables you to correct any configuration issues and perform a new device update.
  7. Select PERFORM UPDATE.
