Use this procedure on Extreme Platform ONE Networking to configure a Tunnel Concentrator Service that includes
either a single Tunnel Concentrator instance or an HA pair of instances.
On Extreme Platform ONE Networking, select Network
Policies, then select Menu > Common Objects > Network > Tunnel Concentrator
Services.
Select an existing service or select (Add) to create a new service.
Enter a Name for the service.
Select the type of Tunnel Concentrator service:
Single Tunnel
Concentrator—A service with a single instance.
Redundant Tunnel
Concentrator—A service with a pair of instances for
HA.
Optional. Select Secure connection (IPsec) if
you want encrypted tunneling.
For Tunnel IP Address/CIDR, enter the IP address and network mask
that terminates the tunnel.
Optional. For Gateway, enter the address of
the default gateway.
HA only. Enter the VRRP Router ID.
For Native VLAN, enter a VLAN ID.
Complete the following fields with details for
each Tunnel Concentrator instance. If you are configuring redundancy, complete
these fields separately for both instances:
Device Tunnel
Concentrator—Select the Tunnel Concentrator instance that
you want to apply to this role.
Tunnel Port—Enter the
port for tunnel termination.
VLAN ID—Enter the VLAN ID
for this instance.
IP Address (HA
only)—Enter the IP address of the tunnel termination point for this
instance.
Bridge Port—Select the
bridge port for this instance.
Configure keepalive settings for this Tunnel
AP
Keepalive Interval (seconds)—Set the keepalive interval for
the sending of keepalives to tunnels that aren't being used.
AP
Keepalive Retries—Set the maximum number of times that the
AP resends a failed keepalive before setting the tunnel status to Inactive.
Optional. To provision an IP address pool for
clients that connect to this tunnel, select Tunnel Concentrator Address
Pool and configure the following fields to define the
range:
Address Pool Profile Name—A name for the pool.
Tunnel
Concentrator Address Pool Start—The starting IP
address.
Tunnel Concentrator
Address Pool End—The ending IP address.
Tunnel
Concentrator Address Netmask—The netmask for the
range.
Tunnel
Concentrator Address Next Hop—The next hop router.
Select Save.
Repeat this procedure if you want to configure
additional Tunnel Concentrator services.
