Configure Tunnel Concentrator Service
Use this procedure on ExtremeCloud‌ IQ to configure a Tunnel Concentrator Service with either a single Tunnel Concentrator instance or an HA pair of instances.
For detailed field descriptions, see Tunnel Concentrator Service Settings.
  1. On ExtremeCloud‌ IQ (Classic), go to Configure > Common Objects > Network > Tunnel Concentrator Service.
  2. Select an existing service or select (Add) to create a new service.
  3. Enter a Name for the service.
  4. Select the type of Tunnel Concentrator service:
    • Single Tunnel Concentrator—A service with a single instance.
    • Redundant Tunnel Concentrator—A service with a pair of instances for HA.
  5. For Tunnel IP Address/CIDR, enter the IP address and network mask that terminates the tunnel.
  6. (Optional). For Gateway, enter the address of the default gateway.
  7. (HA only). Enter the VRRP Router ID.
  8. For Native VLAN, enter a VLAN ID.
  9. Complete the following fields with details for each Tunnel Concentrator instance. If you are configuring redundancy, complete these fields separately for both instances:
    • Device Tunnel Concentrator—Select the Tunnel Concentrator instance that you want to apply to this role.
    • Tunnel Port—Enter the port for tunnel termination.
    • VLAN ID—Enter the VLAN ID for this instance.
    • IP Address (HA only)—Enter the IP address of the tunnel termination point for this instance.
    • Bridge Port—Select the bridge port for this instance.
  10. Configure keepalive settings for this Tunnel Concentrator service:
    • AP Keepalive Interval (seconds)—Set the interval for sending keepalives to tunnels that aren't being used.
    • AP Keepalive Retries—Set the maximum number of times that the AP resends a failed keepalive before setting the tunnel status to Inactive.
  11. Select Save.
  12. Repeat this procedure if you want to configure additional Tunnel Concentrator services.
What to do Next
Assign your Tunnel Concentrator Service(s) to a User Profile
