Configure Tunnel Policy
Use this optional procedure on ExtremeCloud‌ IQ (Classic) to configure a tunnel policy that points to your Tunnel Concentrator service(s). You can apply the policy to different user profiles to quickly provision Tunnel Concentrator across multiple user profiles.
Whenever you add Tunnel Concentrator services to a User Profile in a combination that does not match an existing Tunnel Policy, a new Tunnel Policy gets generated automatically with an autogenerated name. You can use this procedure to edit or rename the policy.
  1. Go to Configure > Common Objects > Network > Tunnel Policies.
  2. Select an existing tunnel policy or select (Add) to create a new policy.
  3. Enter a Name for the policy.
    Tip
    Tip
    If this is an existing tunnel policy that was autogenerated, you can rename the policy by entering a new name and then selecting Save.
  4. Select Tunnel Concentrator.
  5. Assign one or more Tunnel Concentrator services to provide the tunnel destination for this profile:
    • Primary (Required)—Assign a service that will provide the primary tunnel destination for this profile.
    • Secondary (Optional)—Assign a different service as secondary tunnel.
    • Tertiary (Optional)—Assign a third service as tertiary tunnel.
    Optionally, you can select the (Add) icon to open a Tunnel Concentrator service configuration window where you can configure a new service that gets applied to the corresponding tunnel destination for the tunnel policy.
  6. Select Save.
