Log Reporting Field Descriptions
Table 1. Log Reporting Field Descriptions
FieldDescription
System Log LevelThe system log covers local log reporting.
Log Level
The minimum severity level for the System Log. System messages that meet or exceed this severity level get reported in the System Log while messages that don't meet this severity level get ignored.
The list of severity levels, in order of most severe to least severe, is:
  • Critical
  • Major
  • Minor
  • Information
  • Debug
SyslogSyslog reporting logs messages to a syslog server.
Application FacilitySet the facility code that gets used to label syslog messages. The range of values is local0 through local6.
ServersYou can assign up to three syslog servers.
ServerThe IPv4 address of the syslog server.
PortThe port on the syslog server that is used for log reporting. The default is 514.
ProtocolThe protocol for syslog reporting to this syslog server. The values are UDP (the default setting) or TCP.
Level
The minimum severity level for message logging to this syslog server. Syslog messages with a severity that meets or exceeds this level get logged whereas syslog messages with a severity that falls below this level do not get logged on this server.
The list of severity levels, in order of most severe to least severe are:
  • Critical
  • Major
  • Minor
  • Information
  • Debug
