Whenever you add Tunnel Concentrator services to a User Profile in a combination that does not match an existing Tunnel Policy, a new policy gets generated automatically with an autogenerated name. You can use this procedure to edit or rename the policy.
Tip
If this is an existing Tunnel Policy that was autogenerated, you can rename it by entering a new name and then selecting Save
Optionally, you can select the
