Redundancy for Cloud Deployments (Extreme Platform ONE Networking or ExtremeCloud IQ)
Redundancy for Tunnel Concentrator deployments that are managed by Extreme Platform ONE Networking or ExtremeCloud‌ IQ (Classic) can be configured with two levels of redundancy, which provide up to six Tunnel Concentrator instances for tunnel termination:
The following image illustrates a redundant deployment where failovers have occurred at both levels of redundancy resulting in traffic being directed to the secondary tunnel's backup instance.
Redundancy for Extreme Platform ONE Networking or ExtremeCloud‌ IQ Deployments
To assign Primary, Secondary, and Tertiary tunnel destinations, use the User Profile configuration on your management application. The following conditions apply:
To configure HA pairs within a single Tunnel Concentrator service, use the Tunnel Concentrator Service configuration on Extreme Platform ONE Networking or ExtremeCloud‌ IQ (Classic). The following conditions apply:
  • Both instances in a redundant service must be on the same network segment and in the same data center. Layer 2 connectivity is required between each instance in the service.
  • A VRRP address must be configured for the Tunnel Concentrator service if HA pairs are deployed within the service. VRRP is not required if the service includes a single instance only.
    A VRRP address that provides a redundant Tunnel Concentrator service with high availability is different than the VRRP address that provides Tunnel Concentrator with its login address.
