Extreme Tunnel Concentrator v26.01.01 Deployment Guide
Administration
User Management
> Delete User
Extreme Networks, Inc. October 21, 2026
Abstract
How to Use This Guide
Preface
Extreme Support Portal
Create an End Customer Extreme Support Portal Account
Create a Partner Extreme Support Portal Account
Tunnel Concentrator Overview
How Tunnel Concentrator Works
Management Options for Provisioning
Supported Products and Capacities
Tunnel Concentrator Network Architecture
Management Layer Access
Data Layer
VRRP
Redundancy Configuration
Redundancy for Cloud Deployments (Extreme Platform ONE Networking or ExtremeCloud IQ)
Redundancy with ExtremeCloud IQ Controller
Deployment Considerations and Restrictions
ARP Proxy
LAG Configuration Summary
Installation
Requirements
Installation Task Flow
Install ExtremeCloud Edge – Self-Orchestration Deployment
Upload Tunnel Concentrator Image
Install Tunnel Concentrator
Change Admin Password
Generate the Activation License
Select the Management Option
Extreme Platform ONE Networking Configuration
Add Tunnel Concentrators
Configure Tunnel Concentrator Service
Tunnel Concentrator Service Settings
Configure User Profile for Tunnel Concentrator
Configure SSID for Tunnel Concentrator
Deploy Network Policy
Configure Tunnel Policy
Edit Tunnel Concentrator Hostname
ExtremeCloud??? IQ Configuration
Configure User Profile with Tunnel Concentrator
Migrations from VGVA Tunneling to Tunnel Concentrator
Migrate to Tunnel Concentrator using Classification Rules
Migrate to Tunnel Concentrator using a Network Policy
ExtremeCloud IQ Controller Configuration
Configure a GRE Topology for a VLAN
Assign the GRE Topology to the WLAN
Assign the GRE Topology to the Access Point Profile
Administration
Log in to Tunnel Concentrator
Tunnel Concentrator User Interface
User Management
Add User
Delete User
Change a User Password (Administrators only)
Change Your User Password
View Dashboards
View Logs
Configure Log Reporting
Log Reporting Field Descriptions
Configure Packet Captures
Ping a Node
Create Backup File
Upgrade Tunnel Concentrator
Appendix
Installation Example
ExtremeCloud??? IQ (Classic) Configuration Example (Alternative Flow)
Delete User
Use this procedure to delete an existing user from
Tunnel Concentrator
Log in to
Tunnel Concentrator
Go to
Administration
Accounts
From the user list, select the user account that you want to delete.
Select the
(Delete User) icon.
Select
Delete
