Complete the tasks in the following flow to complete the installation and initial setup of Tunnel Concentrator on the Universal Compute Platform.
Before you Begin
Review Requirements and make sure that you meet the full list of requirements for your deployment.
| Procedure | Description | |
| 1 | Install ExtremeCloud Edge – Self-Orchestration Deployment | Install an ExtremeCloud Edge – Self-Orchestration deployment on Universal Compute Platform. |
| 2 | Upload Tunnel Concentrator Image | Upload Tunnel Concentrator image to Universal Compute Platform. |
| 3 | Install Tunnel Concentrator | Install the Tunnel Concentrator application on Universal Compute Platform. |
| 4 | Change Admin Password | As a best practice, change the admin password immediately following the first login. |
| 5 | Generate the Activation License | Activate the license for your installation. |
| 6 | Select the Management Option |
Select the management application that you want to use for tunnel provisioning.
