If you are using Extreme Platform ONE Networking as your management application, complete the tasks in the following task flow to provision tunneling services for Tunnel Concentrator.
Before you Begin
Tunnel Concentrator instances must be installed already. For details, see Installation.
You must have an existing Network Policy with at least one SSID. You will configure Tunnel Concentrator within these elements. For help with Network Policies and SSIDs, see Extreme Platform ONE Networking User Guide.
| Task | Description | |
| 1 | Add Tunnel Concentrators | Onboard your installed Tunnel Concentrator instances to your management application. |
| 2 | Configure Tunnel Concentrator Service | Configure a tunneling service that uses a single instance of Tunnel Concentrator or a redundant HA pair of instances. |
| 3 | Configure User Profile for Tunnel Concentrator | Assign your Tunnel Concentrator service to a User Profile. |
| 4 | Configure SSID for Tunnel Concentrator | Assign the User Profile with the Tunnel Concentrator settings to SSIDs within a Network Policy. |
| 5 | Deploy Network Policy | Complete a delta push to deploy the Network Policy to affected devices. |
