Configure a Generic Routing Encapsulation (GRE) tunnel topology for a given VLAN and assign Tunnel Concentrator instances to the VLAN.
Multicasting is not supported in Tunnel Concentrator v26.01.01. In addition, it's not supported to disable Block Non-Essential Broadcasts.
- Log in to ExtremeCloud IQ Controller.
- Go to .
- Configure the following
parameters:
- VLAN Name
- Name of the GRE
- Mode
- Select GRE
for a Generic Routing Encapsulation (GRE) tunnel.
- VLAN ID
- The ID of the VLAN.
This value must be unique.
- Tagged
- Specify whether the egress
port traffic is tagged or untagged. Most GRE VLAN topologies must be
tagged. Each concentrator can support only one untagged topology. Select
Tagged to tag the
topology.
- Tunnel Concentrators
- List of Tunnel
Concentrators.
Select a concentrator from the list, then select
Add. You can add up to three concentrators to a
single topology. When more than one termination point is added
to the list, failover is supported.
The order of the termination points is significant. The primary concentrator
must be the first termination point in the list. The AP issues a
ping request to the first termination point. If that request
fails, it pings the second point, and then the third point. With
this organization, you can use the same three concentrators for
multiple VLANs, and by varying the termination point order for
each VLAN, you can balance the traffic load.
It is a best practice to configure more than one Tunnel Concentrator per
VLAN topology for failover. A topology that uses a single generic (non-encrypted) GRE
tunnel, without configured backups, is not using the available mechanisms to detect whether
a Tunnel Concentrator is down. Therefore, no AP alarms related to the tunnel connectivity
are generated for such a topology.
- Load Balance
- This checkbox is
visible only when the list of concentrators has more than one
element. Check Load
Balance to load balance APs between concentrators.
- Select Save.
