Select the management application that you want to use to provision tunnels for Tunnel Concentrator.
Primary Controller IP Address
Backup Controller IP Address (only if a backup controller exists).
Application Key—Enter the application key of the controller. If you do not have a key, you can generate one from Tunnel Concentrator. For details, see the subsequent Note.
Application Password—Enter the login password for the controller.
If you do not have an application key, select Generate Application Key, complete the following fields with controller login information, and then select Generate:
Primary Controller IP address
Admin Username
Admin Password
Read-only account—Enter the username for the read-only account for this Tunnel Concentrator instance.
You can also obtain the application key from the Administration > Accounts page of ExtremeCloud IQ Controller.
What to do Next
Provision tunneling services using your management application. Go to the configuration chapter that matches the management option that you selected:
