For a list of field descriptions for the Tunnel Concentrator Service configuration on ExtremeCloud IQ, see Tunnel Concentrator Service Settings. All fields are mandatory configurations, unless indicated otherwise.
| Field | Description |
| Name | Enter a name for the Tunnel Concentrator Service. |
| Description | (Optional) Enter a description for the Tunnel Concentrator Service. |
Single Tunnel Concentrator Redundant Tunnel Concentrator |
Select one of the following
options:
| Tunnel IP Address/CIDR | Enter the IP address and network mask
to which APs should direct tunneled traffic (for example,
10.10.10.3/24). Note that address functionality differs
depending on whether or not you configured High Availability:
| Gateway | (Optional) Enter the IP address of the default gateway. Note: The address must
be on the same subnet as the address for Tunnel IP
Address/CIDR.
| VRRP Router ID | (Redundant Tunnel Concentrator only)
Enter the ID for the VRRP router. This value gets assigned to both the primary and backup Tunnel Concentrators (range 1–255). The VRRP Router ID must be different for each cluster of VRRP devices. In addition, the ID must be different from the VRRP Router IDs that were configured on the data ports for the individual Tunnel Concentrator instances. |
| Native VLAN | Enter the Native VLAN ID. This VLAN is untagged. |
Note: If you
selected Redundant Tunnel Concentrator Service, the
fields in this section appear twice because the service
includes two instances. In this case, complete the fields
separately with values that are relevant to each
instance.
| Device Tunnel Concentrator | From the drop-down, select a specific
Tunnel Concentrator device instance to assume this role in the
service. Note: For a redundant service, both instances within the service
must belong to the same Network Policy.
| Tunnel Port | From the menu, select a port for the tunnel for this Tunnel Concentrator instance. If you are deploying LAG on this Tunnel Concentrator, select a LAG port. |
| VLAN ID | Select the tunneling VLAN ID for this Tunnel Concentrator instance. If the VLAN is untagged, select Untagged. |
| IP Address | (Redundant Tunnel Concentrator only) Enter an IP address to act as tunnel termination point for this instance in the HA pair. Data that goes from the AP to the Tunnel IP Address gets redirected to this IP Address when this Tunnel Concentrator is active. Note: These IP addresses must be on the same
subnet as the Tunnel IP Address/CIDR that this service
uses.
| Bridge Port | From the menu, select a bridge port for the tunnel for this Tunnel Concentrator instance. If you are deploying LAG on this Tunnel Concentrator instance, you can select a LAG port, although it's not mandatory. |
| Keepalive Settings | |
| AP Keepalive Interval (seconds) |
This parameter specifies the interval that APs use for sending keepalives to Tunnel Concentrator. A keepalive consists of a ping that the AP sends inside a tunnel, after which the AP listens for a response. At each interval, the AP sends a keepalive down each tunnel that is not in use, and which leads to a Tunnel Concentrator service (primary, secondary, and tertiary tunnels). The AP listens for Tunnel Concentrator's response and tracks the results for each tunnel separately.
Possible values are 1–60 seconds. The default is 3 seconds. Note: APs send
keepalives only to tunnels that are not in use. If the AP
detects that the tunnel is in use, the AP sets the tunnel
status to Active, but does
not send a keepalive.
| AP Keepalive Retries |
This parameter specifies the maximum number of retry attempts for a failed keepalive before the AP changes the tunnel status to Inactive. A failed keepalive is a keepalive where the AP did not receive a response from Tunnel Concentrator within the allotted interval, as specified by AP Keepalive Interval. If a keepalive interval passes where the AP did not receive a keepalive response from a given tunnel:
Possible values are 1–10 retries. The default is 5 retries. Note: If an AP
receives a keepalive response for an inactive tunnel, the AP
changes the tunnel status to Active and continues to send keepalives at regular
intervals. However, the number of previous keepalive retry
attempts for this tunnel resets to 0.
| Broadcast/Multicast Control | |
| Permitted Multicast IP Addresses |
Note: Not supported in v26.01.01.
| Block Non-Essential Broadcast | When this setting is selected (the
default setting), the Tunnel Concentrator service blocks all
broadcast traffic, except for ARP and DHCP traffic. Note: It's not
supported in v26.01.01 to disable this
setting.
| ARP Proxy | When this setting is selected (the
default setting), the Tunnel Concentrator service maintains an
ARP table and can proxy and respond to ARP requests. Note: It's not supported in v26.01.01 to disable this
setting.
