Data Layer
The Data layer handles functions related to data traffic encapsulation and traffic forwarding. The data layer allows access using one of four data ports from the underlying host. Each port connects to a dedicated internal virtual switch that can connect to external network devices.
The following image provides an example of a flow between a wireless access point and a Tunnel Concentrator HA deployment that is managed by Extreme Platform ONE Networking or ExtremeCloud‌ IQ. In this example, the two Tunnel Concentrators share a VRRP address that is configured from the management application for the Tunnel Concentrator service. Traffic from the access point reaches the shared VRRP address and is redirected to the active Tunnel Concentrator in the HA pair. The traffic flows through the data ports into the Tunnel Concentrator data layer.
The VRRP configuration that provides redundancy for an HA deployment is configured in Extreme Platform ONE Networking or ExtremeCloud‌ IQ (depending on which management application you are using), and is different than the VRRP configuration on a data port that provides access to the management interface.
Data Flow from Access Point for HA Deployment (Extreme Platform ONE Networking or ExtremeCloud‌ IQ)
