How to Use This Guide
Follow the prescribed chapter order to plan, install, configure, and administer the Extreme Tunnel Concentrator application.
Table 1. Extreme Tunnel Concentrator Deployment Flow
ChapterDescription
1Tunnel Concentrator OverviewReview the overview information in this chapter to plan your deployment.
2InstallationUse the procedures in this chapter to install and activate the Tunnel Concentrator application.
3Use the chapter that corresponds to your management application:After installation, configure tunneling services from your selected management application. Use only the chapter that applies to your management application.
4AdministrationOnce everything is up and running, use this chapter to monitor and maintain your deployment on an ongoing basis.
For installation and configuration examples, go to Appendix.
