The Tunnel Concentrator instance is locked to the VF number. By default, the first application instance on a host uses VF01 for all ports, the second application uses VF02, and the third uses VF03. We recommend that you retain the default VF assignments.
The Assigned Virtual IP Address field uses the VRRP virtual IP address that you assigned to the data port on Universal Compute Platform. This address provides Tunnel Concentrator with a login URL for the GUI.
As a best practice, change the admin password immediately after you log in using the default admin credentials.
