Before you install Tunnel Concentrator, make sure that you meet the following requirements:
Licensing and Activation Prerequisites
Downloads/ExtremeCloud/Extreme Tunnel Concentrator.Universal Compute Platform Prerequisites
1130C
2130C
3150C
4120C
Extreme Platform ONE™ Networking or ExtremeCloud™ IQ (Classic) Prerequisites
Note the following:
For configuration information, see Extreme Platform ONE Networking User Guide or ExtremeCloud IQ (Classic) User Guide.
ExtremeCloud IQ Controller Prerequisites
If you choose to deploy ExtremeCloud IQ Controller, note the following:
You must configure connectivity to the controller from the Universal Compute Platform over TCP port 5825.
Configure a read-only user account on the controller that is different from the standard admin account.
Tip
As a best practice, set up separate read-only accounts for each Tunnel Concentrator instance. For example, if you have six different Tunnel Concentrator instances, configure six dedicated read-only accounts and the standard admin account. However, while it's a best practice to have multiple read-only accounts, it's not mandatory.For ExtremeCloud IQ Controller configuration information, see ExtremeCloud IQ Controller User Guide.
Reserved IP Ranges
The following table displays the reserved IP addressing ranges for use with Tunnel Concentrator.
| Purpose | IP Range | Details |
| Tunnel Concentrator Application Network | 10.0.2.0/24 | This range is non-configurable. The range forms the attachment point for management access to the Tunnel Concentrator application. |
| Pod Network | The Pod segment that you assigned on the host (the default range is 10.96.0.0/16) | This is the segment range for the Pod Network that was assigned on Universal Compute Platform during host cluster creation. Please review cluster configuration on host to confirm. |
Firewall Requirements
The following table lists firewall requirements for Tunnel Concentrator.
| Service | Protocol | Ports |
| Domain Name System (DNS) | UDP | 53 |
| Dynamic Host Configuration Protocol (DHCP) | UDP | 67 and 68 |
| Network Time Protocol (NTP) | UDP | 123 |
| Cloud Communication (to ExtremeCloud IQ or Extreme Platform ONE Networking) | TCP | 8090 |
| Tunnel Concentrator communication (HTTPS) | TCP | 5825 and 443 |
| Generic Routing Encapsulation (GRE)—if IPsec is disabled. | GRE | N/A |
| IPsec - Network Address Translation Traversal (NAT-T) | UDP | 4500 |
| IPsec - Internet Key Exchange (IKE) | UDP | 500 |
| Secure Shell (SSH) for troubleshooting | TCP | 22 |
If you are onboarding Tunnel Concentrator to the cloud, connectivity to the following services is required.
| Domain Name | IP Addresses | Protocol | Port | Description |
| hac.extremecloudiq.com | 34.253.190.192 ~ 34.253.190.255 | HTTPS | 443 | Onboarding to Extreme Platform ONE Networking or ExtremeCloud IQ |
| <rdc>-inlets.extremecloudiq.com | Dynamic IP range | TCP | 8090 | Ongoing connection to Extreme Platform ONE Networking or ExtremeCloud IQ |
